I did box > _viewbase > _viewsection. Worked okay, no crash (Xubuntu 19.04, BricsCAD latest and greatest). Is it geometry related perhaps? You probably did an audit, hard to pinpoint the crash in a topic. I would issue a support request if I were you.
Hi top, could you describe the steps that causes the crash? Can you reproduce the crash?
An error occurs on the making section view. Command: _viewsection
I did
box
>_viewbase
>_viewsection
. Worked okay, no crash (Xubuntu 19.04, BricsCAD latest and greatest). Is it geometry related perhaps? You probably did anaudit
