(Command "IncludePlotStamp" "0") not working in lisp routine
Cannot seem to get the (Command "IncludePlotStamp" "0") to work in this lisp routine.
The PDF is created, but w/ a PlotStamp.
When invoking (Command "IncludePlotStamp" "0") prior to the lisp routine to return a PDF w/out the PlotStamp.
Why isn’t the (Command "IncludePlotStamp" "0") functioning prior to the plot  command?
Thanks, Mike
;DWG to PDF BricsCAD    10:18 AM 6/11/2019
;Saves to C:\Users\mdunn\Documents   (not sure how to change this)
;B Size, PS, Extents, Color, PDF, NO STAMP
(Command "IncludePlotStamp" "0")    ;Plot Stamp Off
(defun c:PDF-NoStamp-Brics ()   ;starts lisp routine
(Command "-Plot"    ;Command Line Plot Command
"YES"   ;Detailed plot configuration?
""      ;Enter a layout name, Keeps ext'g name (Layout1)
"Brics PDF 8-23-2018.pc3"   ;Enter an output device name
"Ledger"    ;Enter paper size
"Inches"    ;Enter paper units
"Landscape" ;Enter drawing orientation
"NO"        ;Plot upside down?
"Extents"   ;Enter plot area
"FIT"       ;Enter plot scale
"Center"    ;Enter plot offset
"YES"   ;Plot with plot styles?
"acad.ctb"  ;Enter plot style table name
"YES"   ;Plot with lineweights?
"NO"        ;Scale lineweights with plot scale?
"YES"   ;Plot paper space last?
"NO"        ;Remove hidden lines in paper space?
"No"        ;Write the plot to a file?
"NO"        ;Save changes to page setup
"Yes")  ;Proceed with plot
;(Command "IncludePlotStamp" "1")   ;Plot Stamp On
(princ "\n\t     PDF no Plot Stamp to C:/Users/mdunn/Documents ")   ;Comment @ routine completion
(princ) ;No Nil returned
)   ;Ends PDF-Brics lisp routine
It's probably not working because you're setting it outside of your command function. It is also a environment variable, not a command, so it's more efficient to use setvar/getvar calls. The plot output folder is governed by another variable "PlotOutputPath". Change this to direct where you want your prints to go to.
Try the attached
;DWG to PDF BricsCAD 10:18 AM 6/11/2019 ;Saves to C:\Users\mdunn\Documents (not sure how to change this) ;B Size, PS, Extents, Color, PDF, NO STAMP (defun C:PDF-NoStamp-Brics ( ) ;starts lisp routine ; Save & set environment variables (acet-sysvar-set (list ( "CMDECHO" 0 "IncludePlotStamp" 0 ;Plot Stamp Off "PlotOutputPath" "C:/Users/mdunn/Documents" ;Plot file location. Change to your preferred folder ) ) ) (Command "._-Plot" ;Command Line Plot Command "YES" ;Detailed plot configuration? "" ;Enter a layout name, Keeps ext'g name (Layout1) "Brics PDF 8-23-2018.pc3" ;Enter an output device name "Ledger" ;Enter paper size "Inches" ;Enter paper units "Landscape" ;Enter drawing orientation "NO" ;Plot upside down? "Extents" ;Enter plot area "FIT" ;Enter plot scale "Center" ;Enter plot offset "YES" ;Plot with plot styles? "acad.ctb" ;Enter plot style table name "YES" ;Plot with lineweights? "NO" ;Scale lineweights with plot scale? "YES" ;Plot paper space last? "NO" ;Remove hidden lines in paper space? "No" ;Write the plot to a file? "NO" ;Save changes to page setup "Yes" ;Proceed with plot ) (princ (stcrat "\n\t PDF no Plot Stamp to " (getvar 'PlotOutputPath))) ;Comment @ routine completion (acet-sysvar-restore) ; Reset environment variables (princ) ;No Nil returned ) ;Ends PDF-Brics lisp routineRegards,
BricsCAD V19 Ultimate
Quickly create HELP links on your forum posts0
