text printed to small
all texts are printed smaller than set and displayed on the screen. See attached images.
In ~/Bricsys/BricsCAD/V19x64/en_US/Support you'll find a fontmapping file default.fmp. You can edit that one, Windows is the same.
Does it contain a clue?
I had the same issue on Mac version time ago. I cannot remember how I fixed it, but it had to do with the configuration of PUBLISH when exporting to PDF. This is how I have it configured right now:
For the record, there has been a fix in BricsCAD(Linux) V19.2.15 and BricsCAD(Mac) V19.2.12 for this problem.
(which was already communicated to Hans Hermans in a support request)- PDF PRINT/PUBLISH/EXPORT
Fixed improper size of True Type font texts/mtexts generated by print/export/publish.
0 - PDF PRINT/PUBLISH/EXPORT
