Unisolate entities
I use isolate/unisolate layers often.
Isolate entities is also very useful - but where is the 'UNisolate entities? That would be very useful. It would save having to use the structure browser, which is a bit slow.
The unhide command unhides isolated/hidden entities
But it unhides everything. With layers, it unhides to the last set of visible layers. Is there a setting which makes 'unhide' do that with the hidden objects?
AFAIK
Structure Panel/Browser is the only option to unhide a selection
of hidden objects.Not sure if Structure Tree needs Platinum, BIM or Mechanical license (?)
Well an 'unhide to last visible' would be good
@Anthony de Carnys said:
Well an 'unhide to last visible' would be goodI wholeheartedly agree!
How useful it would be to have (optional) independent undo/redo control over:
1. hide/unhide entities. (ctrl+alt+z)
2. view position and zoom. (ctrl+shift+z)
3. all other commands that actually change the model/drawing. (ctrl+z)0 -
Independent from that issue,
2. is mandatory anyway
