Unisolate entities
I use isolate/unisolate layers often.
Isolate entities is also very useful - but where is the 'UNisolate entities? That would be very useful. It would save having to use the structure browser, which is a bit slow.
  • The unhide command unhides isolated/hidden entities
  • But it unhides everything. With layers, it unhides to the last set of visible layers. Is there a setting which makes 'unhide' do that with the hidden objects?
  • AFAIK
    Structure Panel/Browser is the only option to unhide a selection
    of hidden objects.
    Not sure if Structure Tree needs Platinum, BIM or Mechanical license (?)
  • Well an 'unhide to last visible' would be good
    I wholeheartedly agree!
    How useful it would be to have (optional) independent undo/redo control over:
    1. hide/unhide entities. (ctrl+alt+z)
    2. view position and zoom. (ctrl+shift+z)
    3. all other commands that actually change the model/drawing. (ctrl+z)
  • Michael Mayer
    edited November 2019
    Independent from that issue,
    2. is mandatory anyway :)
