Polygon objects?
The county we do work in sometimes requires digital submissions of various GIS-related items, such as drainage areas. Some of these objects need to be polygons (NOT closed polylines). The reason is because aside from the boundary itself, a closed polyline contains no pertinent information, versus a polygon object, which contains information like what other polygons fall within that area. Is this feature totally absent from BricsCAD?
Assuming you are talking about Mpolygons:
I think this is one of those cases where BricsCAD will only display the entity (but I am still using V18).If you really need to create such an entity: it is possible to entmake one.
See here (Note: remove the filename and arxload stuff):
https://www.theswamp.org/index.php?topic=29131.msg346914#msg3469140
