Polygon objects?
The county we do work in sometimes requires digital submissions of various GIS-related items, such as drainage areas. Some of these objects need to be polygons (NOT closed polylines). The reason is because aside from the boundary itself, a closed polyline contains no pertinent information, versus a polygon object, which contains information like what other polygons fall within that area. Is this feature totally absent from BricsCAD?
For polygon info:
https://knowledge.autodesk.com/support/autocad-map-3d/learn-explore/caas/CloudHelp/cloudhelp/2019/ENU/MAP3D-Use/files/GUID-C106D992-26DF-4935-9DDA-3C3B3A528860-htm.html
