(V20)MULTILEADER does not display the character size correctly.
(settings) When drawing with both the text size and arrow size set at 2 mm and the overall scale set at 5, only the text is drawn at 2 x 5 x 5 = 50 mm. If you copy it and edit only the text, only the text is multiplied by 5 (50 x 5 = 250 mm). MULTILEADER is also known to decompose when opened with AUTOCAD.
Put in a bug report on the support page. I did because V20 has misaligned my multileader. So I think the new v20 multileader system is faulty.
Yes, I did.
I received the following reply.Our developers are aware of this issue, I will return with future notice when the problem is fixed.
Best Regards,Thank you.
Howdy, Stranger!
