Changing how right click command information is presented
That is a Bricscad Special Feature, called "Quad" menu.
You can customize Quad behavior, when to appear or if at all
in Status Bar and Settings.I think, to get the same functionality for a standard text based
RMB option menu, you have to go into CUI Customization Dialog
and add a lot of Tools manually from several Tabs in the Dialog.
Like Mouse behavior and such.0 -
To display the Shortcut Menu when the Quad is active you must do a 'long right click' (= hold down the right mouse button a bit longer). This behavior is controlled through bitcode 16 of the SHORTCUTMENU system variable. Edit this variable to control the shortcutmenu mode (default, edit or command).
Perfect thanks Louis
Thanks to all the respondees
