Jumpy cursor when command is active
I have smooth movement of the cursor within Briscad v20.2.06
The issue is when a command is active, the cursor responds as if it is snapping to a grid (Snap is turned off)
Is there another variable I am missing?
V20.2.06
Windows 10
4k display
Thank you for your response, any are appreciated....
I found the culprit:
(setvar "SNAPTYPE" 0)
I had it at 2, which set it to a dynamic grid snap
Thanks James,
Legend for coming back and updating, cheersgoodonline said:I found the culprit:
Thanks James,
