Blockify and Block Descriptions
So I am a convinced Blockify user, and find that in many of my drawings in the MEP Field it is a real time saver. I do have a special need, but am not sure of how to go about it. I am on BricsCAD 19. and I do a lot of Fire Alarm and Security System design work. With conventional Blocks I can add Attributes, say to a Horn/Strobe 15cd (candela) and 001-001 (device ID). Now I cannot seem to program the Block into an Auto Count for the Device ID, I have to change each one when I add it to the drawing (which is very time consuming). If I use a standard Block, is there a way to have each time I place the block that the Device ID based upon any beginning criteria I want to use, so that it will Auto Count Up.....ie: 001-001, click the next block insert point and 001-002, 001-003, all the way until I have entered all the devices. And is it possible to do the same thing with Blockify (I click the first group entity it sets the Auto Count at say 001-001, then for each item that it auto Blockify's it will count up by one-001-002 on and on. I hope I have described the process I am looking to do in a manner that is easily understood. Thanks All.
Try the Number command. See https://help.bricsys.com/hc/en-us/articles/360012615633-Number
Hi Louis,
Thank you for the valuable information. I tried a number of times to see if the NUMBER command would accept the protocol of the numbering schema, but it did not seem to work for me. I am going to experiment more and see if it is on me, or if it just the restrictive nature of the command itself. It is a start. Thanks Again
