Howdy, Stranger!
It looks like you're new here. If you want to get involved, click one of these buttons!
Blockify and Block Descriptions
So I am a convinced Blockify user, and find that in many of my drawings in the MEP Field it is a real time saver. I do have a special need, but am not sure of how to go about it. I am on BricsCAD 19. and I do a lot of Fire Alarm and Security System design work. With conventional Blocks I can add Attributes, say to a Horn/Strobe 15cd (candela) and 001-001 (device ID). Now I cannot seem to program the Block into an Auto Count for the Device ID, I have to change each one when I add it to the drawing (which is very time consuming). If I use a standard Block, is there a way to have each time I place the block that the Device ID based upon any beginning criteria I want to use, so that it will Auto Count Up.....ie: 001-001, click the next block insert point and 001-002, 001-003, all the way until I have entered all the devices. And is it possible to do the same thing with Blockify (I click the first group entity it sets the Auto Count at say 001-001, then for each item that it auto Blockify's it will count up by one-001-002 on and on. I hope I have described the process I am looking to do in a manner that is easily understood. Thanks All.
Origami
Origami is the Japanese word for paper folding. ORI means to fold and KAMI means paper and involves the creation of paper forms usually entirely by folding.
Powered by VanillaForums, Designed by Steam
