How to center Plane DMDistance3D on some line/plane? (symmetry)
Hello :-)
Trying to modelize a servo-motor lever, the thickness of the lever is represented with a parameter "thickness", which I can adjust to get a stronger or lighter lever.
The problem is that modifying the thickness, it does not keep the symmetry of the piece (only one side of the lever is adjusted). I found several constraints for 2D/sketches like "symmetry" which helps for drawing, but in the case of a 3D model, they don't apply.
How to keep the symmetry of the lever while playing with the "thickness" parameter?
How to center the distance between the two planes?
Check out the command options that give you more control over 3d constraints. For example, you can refer distances to WCS planes:
: _dmDistance3d
Select a first entity or specify [Use as/WOrld/BLock/selection options (?)]:wo
Select reference coordinate system subentity [Origin/X axis/Y axis/Z axis/XY plane/YZ plane/ZX plane]:So you could set a distance constraint between one of the lever faces and the ZX-plane equal to "thickness/2".
As Scott said, use a
DMDISTANCE3D
constraint back to the ZX plane. see modified form of your model attached.I also find it more flexible to use a Hole component to create the holes. This allows you to use the Block option (a hole component is a type of block) to position the hole using the blocks coordinate system. Particularly useful for when you are trying to position something with a curved surface.
BricsCAD V20 Ultimate
CAD Concepts0 -
That worked, thank you
