What setting controls the contrast ...
for the 3 options and the status bar elements SNAP, GRID, ... that are 'OFF'?
Ah, yes, ....
Dark Mode still has some flaws here and there.
Maybe there is no Setting but coded into GUI.I think that needs a feature/change request and they
will change it.0 -
I was hoping there was a setting and I was just unable to find it.
I guess I'll eventually learn positionally where things are. Now I have to hover over the dark boxes in the status bar to get a hint as to what it represents.
"Dark Mode still has some flaws here and there" - I guess this is true on windows, but on Linux, it is quite a mess of hardcoded values and theme-dependent settings. My preferred gtk-theme (Numix) looks horrible with dark-interface enabled, the standard gnome-theme in dark-mode (Adwaita:dark) looks already more decent, but the missing contrast of the status bar buttons is shared by both. IMO, BricsCAD would need a preference to switch between selected themes when you switch dark-mode. See for example the attached theme preference dialog that Inkscape offers - a real role model.
