LISP Crash, does not make sense
Why?
Got a new printer for home, loader HP printer driver, worked good.
Created *.pc3 from HP Driver.
Created Plot Lisp routine which crashed @ paper size (line 15).
Lisp attached (BPEC-H.lsp).
Had to add line 19, below.
"" ;Returns default which is <11×17>, Why is this needed!
The default <11×17> is what the Lisp asked for.
Why did it NOT work w/out adding the "" ?
Sure, I should be thrilled I found the work around, but I want to know why 11x17 didn’t work when it was the printer driver data.
Lines 16,17,18 explain the crash/fix.
Thank you in advance for any help in understanding the "why" of it.
Mike
I think you need to run plot as -Plot to see what the command line wants.
James,
Appreciate your help.
Unless I misunderstand what you are saying, that is how the lisp is written:(Command "-Plot"
"Yes" ;Detailed plot configuration?
"" ;Enter a layout name, Returns ext'g Tab Name
"HP-Color-LazerJet-CP5225n-B.pc3" ;Enter an output device name
"11x17" ;Enter paper size
;;"Enter paper size or ? <11×17>:11x17Paper '11x17' not found"
;;Crashed here, returned above text (in quotes)
;;Had to add next line for the lisp to run. WHY?!!!
"" ;Returns ext'g; Why is this needed!
"Inches" ;Enter paper unitsNotice the <11x17> is the default (line 5 above); my guess is because it is the setting for the paper size in the pc3 file.
Any other ideas?
Or do I misunderstand what you trying to say?
Thanks,
Mike -
The first 'x' on line 16 is actually not an 'x' but another character.
Roy,
Ah, you have good eyes, I didn't notice that.
But when I type a 'x' beside the 'other character', sure enough they are not the same animal.
Attachment shows both, 1st 'x' is an actual 'x', 2nd 'x' is the 'other character'; note how it is centered & not aligned as the other text is.
Now the question is where did this 'other character' come from?
Looked in the printer Preferences & Properties & there is no way to change the text where the paper size for 11x17 is shown; it is by selection only.
So perhaps the driver data for the paper size is where the errant character came from. Not sure how to fix that.
Thanks for your help, I never would have noticed the 'other character', but now I will be looking for similar 'other character' weirdness if other strange things like this happen in other lisp routines.
If you have a solution editing out the 'other character' please let me know.
Thanks,
Mike -
Attachment wouldn't load in previous post.
2nd try. -
You may need to make a custom sheet size that is 11x7, I used a copy and paste once before to get the correct title and not miss something think it was acad. Not sure though where to try and copy the line in Briscad.
Howdy, Stranger!
