nwcout from Bricscad
Is there a way to export nwc from Bricscad when file is open, in the same way you can nwcout when in autocad file?
@jdright2711 said:
Is there a way to export nwc from Bricscad when file is open, in the same way you can nwcout when in autocad file?I don't see an option to export NWC.
From what I'm gathering by your question, you can wblock the desired objects and append the wblock dwg in Navisworks.0 -
yeah was thinking that about nwc out. If necessay we can just append the bricscad file as a dwg to navis.
I don't really understand the need export nwc. Navisworks should work fine with [fiil in] your format. I was designed as a convertor to do so. I see masses of people importing exporting to different Autodesk formats. Just a waist of time.
