nwcout from Bricscad
Is there a way to export nwc from Bricscad when file is open, in the same way you can nwcout when in autocad file?
    I don't see an option to export NWC.
    From what I'm gathering by your question, you can wblock the desired objects and append the wblock dwg in Navisworks.
  • yeah was thinking that about nwc out. If necessay we can just append the bricscad file as a dwg to navis.
  • Hans Lammerts
    edited February 2021
    I don't really understand the need export nwc. Navisworks should work fine with [fiil in] your format. I was designed as a convertor to do so. I see masses of people importing exporting to different Autodesk formats. Just a waist of time.
