Dimension settings
Dimensions coming in upside-down, vertical and horizontal and when I pick radius or diameter dims the comes in the same way??
Learning Bricscad 2nd week.
  • You may have accidentally changed to a 3D view.
    To switch back use these 2 commands:
    _Ucs > World
    _Plan > Current UCS
  • These setting are correct. (BUT)
    It seems that I need to have to be picked from left to right (horizontal ) top to bottom (vertical) and sometimes when I thy to draw a line from center of a citcle in ortho my ucs turns on and it starts the line on an angle???
  • You can try disabling the DUCS option on the bottom right corner of the BricsCAD
  • Jose,
    Thank you so much that seem to work.
