Dimension settings
Dimensions coming in upside-down, vertical and horizontal and when I pick radius or diameter dims the comes in the same way??
Learning Bricscad 2nd week.
You may have accidentally changed to a 3D view.
To switch back use these 2 commands:
_Ucs > World
_Plan > Current UCS -
These setting are correct. (BUT)
It seems that I need to have to be picked from left to right (horizontal ) top to bottom (vertical) and sometimes when I thy to draw a line from center of a citcle in ortho my ucs turns on and it starts the line on an angle??? -
You can try disabling the DUCS option on the bottom right corner of the BricsCAD
Jose,
Thank you so much that seem to work.
Howdy, Stranger!
