Data extraction from XREF created with smart components
Dear all,
my setup contains a model for structure (BIM) and an xref with smart components (Mechanical). I have chosen this setup since I started in Mechanical and when binding the xref into the model I loose all smart logic. Now I would like to create schedules from within the model. I have create a DXD file as follows:
[Settings] ExtractFromBlocks=1 ExtractFromXrefs=1 CountXrefs=0 CombineEqualRows=1 IncludeNameColumn=1 [Entity Types] * [Properties] Component name|Component name| Size|Nennweite| Rating|Druckstufe|
When inserting this via BIM into the model I receive information contained only in the model not in the xref. Any hints on how to proceed or to setup differently are highly appreciated.
Kind regards
Sebastian
Found a solution:
1#Create custom DXD using DATAEXTRACTION from a defined DWG
2#Load DXD within the project browser as a schedule and load to target file
3#Review BOQ and adapt iteratively the DXD file in a text editorA sample DXD might look like
[Version] 2.0 [PATHS] Piping.dwg|false| [Settings] ExtractFromBlocks=1 ExtractFromXrefs=1 CountXrefs=1 CombineEqualRows=1 IncludeNameColumn=0 FooterStyle=0 FlowDirectionRtoL=0 CSVdelimiter=0 IncludeLayouts=0 [Entity Types] Block|DIN EN 1092-1 Flange 01 B| Block|DIN 2605 Elbow Type 2 90 Deg| Block|DIN EN 1092-2, Absperrschieber, Grundreihe 15| Block|DIN EN 1092-1, Pass- Ausbaustück| Block|DIN 2615 Tee| Block|DIN EN 1092-2, Typ 21 B, Schmutzfänger| Block|DIN EN 10220 Series 1| Block|DIN 2616 Concentric Reducer| Block|DIN EN 1092-1, Absperrschieber, Grundreihe 14| Block|DIN EN 1092-1 Flange 05 B| [Properties] Mechanical component:Component name|Bauteilbezeichnung| Parameters:GasketThickness|Dichtungsdicke| Parameters:Length|Länge| Parameters:OuterDiameter|Aussendurchmesser| Parameters:PartNumber|Bauteilnummer| Parameters:Rating|Druckstufe| Parameters:Size|Nennweite| Parameters:Thickness|Wandstärke| Standard part:Part category|Kategorie| Standard part:Part description|Beschreibung| Standard part:Part type|Typ| [TableFormatOptions] TableStyle=Standard TitleCellStyle=TITLE HeaderCellStyle=HEADER DataCellStyle=DATA [OUTPUT] Table=0 Datalink=0 CSV=0
Howdy, Stranger!
