Data extraction from XREF created with smart components
Dear all,
my setup contains a model for structure (BIM) and an xref with smart components (Mechanical). I have chosen this setup since I started in Mechanical and when binding the xref into the model I loose all smart logic. Now I would like to create schedules from within the model. I have create a DXD file as follows:
[Settings]
ExtractFromBlocks=1
ExtractFromXrefs=1
CountXrefs=0
CombineEqualRows=1
IncludeNameColumn=1
[Entity Types]
[Properties]
Component name|Component name|
Size|Nennweite|
Rating|Druckstufe|
When inserting this via BIM into the model I receive information contained only in the model not in the xref. Any hints on how to proceed or to setup differently are highly appreciated.
Kind regards
Sebastian
  • Found a solution:
    1#Create custom DXD using DATAEXTRACTION from a defined DWG
    2#Load DXD within the project browser as a schedule and load to target file
    3#Review BOQ and adapt iteratively the DXD file in a text editor
    A sample DXD might look like
    [Version]
    2.0
    [PATHS]
    Piping.dwg|false|
    [Settings]
    ExtractFromBlocks=1
    ExtractFromXrefs=1
    CountXrefs=1
    CombineEqualRows=1
    IncludeNameColumn=0
    FooterStyle=0
    FlowDirectionRtoL=0
    CSVdelimiter=0
    IncludeLayouts=0
    [Entity Types]
    Block|DIN EN 1092-1 Flange 01 B|
    Block|DIN 2605 Elbow Type 2 90 Deg|
    Block|DIN EN 1092-2, Absperrschieber, Grundreihe 15|
    Block|DIN EN 1092-1, Pass- Ausbaustück|
    Block|DIN 2615 Tee|
    Block|DIN EN 1092-2, Typ 21 B, Schmutzfänger|
    Block|DIN EN 10220 Series 1|
    Block|DIN 2616 Concentric Reducer|
    Block|DIN EN 1092-1, Absperrschieber, Grundreihe 14|
    Block|DIN EN 1092-1 Flange 05 B|
    [Properties]
    Mechanical component:Component name|Bauteilbezeichnung|
    Parameters:GasketThickness|Dichtungsdicke|
    Parameters:Length|Länge|
    Parameters:OuterDiameter|Aussendurchmesser|
    Parameters:PartNumber|Bauteilnummer|
    Parameters:Rating|Druckstufe|
    Parameters:Size|Nennweite|
    Parameters:Thickness|Wandstärke|
    Standard part:Part category|Kategorie|
    Standard part:Part description|Beschreibung|
    Standard part:Part type|Typ|
    [TableFormatOptions]
    TableStyle=Standard
    TitleCellStyle=TITLE
    HeaderCellStyle=HEADER
    DataCellStyle=DATA
    [OUTPUT]
    Table=0
    Datalink=0
    CSV=0
