Is there a regen setting / variable ?
My circles look like octagonal
  • Set WHIPARC = ON.
  • Thank you so much!!! Life is good again
  • @tomcad143
    You need to be searching the autodesk discussion groups in addition to these. The settings are essentially the same, and this one is common.
    Most of the people that know Bricscad "well", can because they first know autocad well. The two are brothers from another's mothers, if I can properly butcher the saying.
  • Yes, "Twins from different mothers"
