Hello,
is it possible to add a Leader with a predefined Text to a Toolpalette?
If I add it with the command: ^c^c_mleader; then I have to enter the Text manually.
Thank you, in advance.
Make it a block, and adjust it to explode when inserted from the Tools palette.
