View direction of vectors
Is it possible to see in what direction a vector goes?
For instance, if I draw a polyline based shape in a counter clockwise direction, I obviously know the direction. But if I draw a shape which is built up out of different shapes, exploded, trimmed, and joined again, I have no idea of the direction of the vectors. For cnc tool radius correction, it's important to know in what direction it goes.
You can use a linetype with arrows.
*ARROWS,Arrows -> -> -> A,1,[ZIG,ltypeshp.shx,r=-90,x=-0.25,y=0.25,s=0.25],-1
Also when changing Length in Properties - which end will change?
There are a few is anticlockwise lisps for plines then can do Pedit R.
;; get closed polygon's area
(defun ss-pts2area (l)
(/ (apply (function +)
(mapcar (function (lambda (x y)
(- (* (car x) (cadr y)) (* (car y) (cadr x)))))
(cons (last l) l)
l))
2.)
);_force pointset CCW
(setq plent (entsel "\nPick pline"))
(setq co-ord (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 10)) (entget (car plent)))))(if (< (ss-pts2area co-ord) 0)
(command "pedit" plent "R" "")
)0 -
The arrow line type works great!
I have a somewhat related question.
Cad seems to register in what order one draws shapes. If I draw some straightforward shapes, ie first a circle, then a rectangle, the cnc router will first cut out the circle, then the rectangle.
Is there a way to view in what order the shapes have been drawn, and even change this order?0 -
The issue of drawn order has been asked before, I think some code was put forward to remake the entities in a new pick order Google. Re view order try a plain ssget pretty sure selects in drawn order. If you want a fancy zoom to object etc a lot more code.
(defun c:qkdirty ( / ss x)
(setq ss (ssget))
(repeat (setq x (sslength ss))
(command "CHPROP" (ssname ss (setq x (1- x))) "" "C" 1 "")
(alert "Look move this alert out of way")
(princ)
(c:qkdirty)0
