How to permanently turn off Layer Snapshot is saved in VIEW
When I run a lisp routine I've used for decades in AutoCAD to create specific views, Bricscad saves a view snapshot with the view, I do not want it to do that, I need that turned off. In AutoCAD there is a setting I can turn off and layer snapshots are never saved. I can't seem to find that switch in Bricscad. After I run the function I have to go into the VIEW dialog box and reset the switch for each view one at a time, PITA and ruins a time saving function.
BTW, the search feature on these forums is next to useless.
  • The search feature of the Settings command, on the other hand, does work well. Enter 'Snapshot' and find the 'SaveLayerSnapshot' setting...
