How to permanently turn off Layer Snapshot is saved in VIEW
When I run a lisp routine I've used for decades in AutoCAD to create specific views, Bricscad saves a view snapshot with the view, I do not want it to do that, I need that turned off. In AutoCAD there is a setting I can turn off and layer snapshots are never saved. I can't seem to find that switch in Bricscad. After I run the function I have to go into the VIEW dialog box and reset the switch for each view one at a time, PITA and ruins a time saving function.
BTW, the search feature on these forums is next to useless.
  • The search feature of the Settings command, on the other hand, does work well. Enter 'Snapshot' and find the 'SaveLayerSnapshot' setting...
Howdy, Stranger!
It looks like you're new here. If you want to get involved, click one of these buttons!
