Plugin compatible with AutoCad and BricsCad
I made a plugin for AutoCad and can load it successfully. I am now working on BricsCad compatibility but am unable to get it to work with BricsCad. I added a comparative if statement to switch which namespaces and using statements are being used for each program but I cannot get it to work, any help would be appreciated.
Here is my source: https://github.com/y4utech/CADAccessibuildPlugin/tree/010fbc78b36b75fedce79b442f9abb7f6bbdda3d
EDIT: Sorry apparently I posted this three times.
I see that the only project in the solution is still tied to the AutoCAD libraries. In theory, you cannot compile it. Or am I bad looking? It seems that you are trying to create one dll that will work in all programs. It won't work that way.
In the lisp world you have Autocad FAS in Bricscad you have DSE. Same code just compiled in correct platform.
How do I compile it for bricscad then?
Remove references to AutoCAD libraries from the project. And tell us what happens when the library is loaded. How do you load the plugin?
I was missing a reference in the code that I didn't put into the #if. That fixed it Thanks!
