Plugin compatible with AutoCad and BricsCad
I made a plugin for AutoCad and can load it successfully. I am now working on BricsCad compatibility but am unable to get it to work with BricsCad. I added a comparative if statement to switch which namespaces and using statements are being used for each program but I cannot get it to work, any help would be appreciated.
Here is my source: https://github.com/y4utech/CADAccessibuildPlugin/tree/010fbc78b36b75fedce79b442f9abb7f6bbdda3d
EDIT: Sorry apparently I posted this three times.
  • avc
    avc
    edited September 2021
    I see that the only project in the solution is still tied to the AutoCAD libraries. In theory, you cannot compile it. Or am I bad looking? It seems that you are trying to create one dll that will work in all programs. It won't work that way.
  • ALANH
    In the lisp world you have Autocad FAS in Bricscad you have DSE. Same code just compiled in correct platform.
  • How do I compile it for bricscad then?
  • Remove references to AutoCAD libraries from the project. And tell us what happens when the library is loaded. How do you load the plugin?
  • I was missing a reference in the code that I didn't put into the #if. That fixed it Thanks!
