Move to layer of choice
I've tried searching to no avail
Another program I have I can move objects from one layer to another simply by invoking a command and selecting Target Layer then the objects.
I'd like to do that with an Alias in Bricscad but can't find a command that will work.
Or if its available in a menu, but work from Alias is preferred
Help is appreciated thanks.
I'm on Version 18.2.14 (x64) revision 54509
  • (defun c:2lay ( / lay ss)
    (setq lay (cdr (assoc 8 (entget (car (entsel "Select object destination layer "))))))
    (prompt "\nSelect objects to change ")
    (setq ss (ssget))
    (command "chprop" ss "" "la" lay "")
    (princ)
  • that is exactly what I am desiring.
    Big thanks AlanH.
    Made my day!
    Beer? Coffee?
    Need to send :)
  • Not a problem been doing this for like 40 years.
    I have clients all over the world where are you ? I am in Australia.
    Tasmania
    Not coming across the strait though :)
    I enjoy our safe (at the moment) isolation :)
    Must be another way
  • What about the "MATCH" command in Bricscad? "MA"
    Ian that also matches, in my case, the text rotation which I want to retain.
    I'm annotating survey plans for titles office.
    Survey notes have bearings to second, survey plan have bearings rounded, same with distances.
    I just copy and paste the 'notes' bearings and paste to where I will show my 'Plan' details.
    Then I manually round according to standards. Not easy to do standard rounding as it is dependant on length of boundary so three different 'roundings' on one plan.
    I want the same bearings and distances but on different layer.
    There's probably another way? Copy to layer. I have that in a GIS graphics package which is briiliant. Select, Right Click, and option 'Copy to Layer' is there
