Move to layer of choice
I've tried searching to no avail
Another program I have I can move objects from one layer to another simply by invoking a command and selecting Target Layer then the objects.
I'd like to do that with an Alias in Bricscad but can't find a command that will work.
Or if its available in a menu, but work from Alias is preferred
Help is appreciated thanks.
I'm on Version 18.2.14 (x64) revision 54509
(defun c:2lay ( / lay ss)
(setq lay (cdr (assoc 8 (entget (car (entsel "Select object destination layer "))))))
(prompt "\nSelect objects to change ")
(setq ss (ssget))
(command "chprop" ss "" "la" lay "")
(princ)
that is exactly what I am desiring.
Big thanks AlanH.
Made my day!
Beer? Coffee?
Need to send -
Not a problem been doing this for like 40 years.
I have clients all over the world where are you ? I am in Australia.
@ALANH said:
Not a problem been doing this for like 40 years.I have clients all over the world where are you ? I am in Australia.
Tasmania
Not coming across the strait though
I enjoy our safe (at the moment) isolation
Must be another way -
What about the "MATCH" command in Bricscad? "MA"
@Ian Johnson said:
What about the "MATCH" command in Bricscad? "MA"Ian that also matches, in my case, the text rotation which I want to retain.
I'm annotating survey plans for titles office.
Survey notes have bearings to second, survey plan have bearings rounded, same with distances.
I just copy and paste the 'notes' bearings and paste to where I will show my 'Plan' details.
Then I manually round according to standards. Not easy to do standard rounding as it is dependant on length of boundary so three different 'roundings' on one plan.
I want the same bearings and distances but on different layer.There's probably another way? Copy to layer. I have that in a GIS graphics package which is briiliant. Select, Right Click, and option 'Copy to Layer' is there
Howdy, Stranger!
