Can't get the effective name of a parametric block after changing its parameters.
Hi.
I wrote a LSP that gets a parametric block effective name (see EF.lsp).
but when I pick a parametric block I get the anonymous blocks *U* name.
as its tured out,
as long as I don't change the plock parameters I can get the effective name,
but after changing the parameters I can only get the anonymous name.
I also attched a simple parametric block flie to use as an example.
dose any one has an idea on how to solve this issue?...
thanks,
Ari.
as its tured out,
thanks,
Ari.
Hi Arid,
could you try
(setq instHandle (BmLispGet "Instance" ent))
(setq instName (BmLispGet "InstanceName" instHandle)) -
Hi Piet.Piet said:Hi Arid,
could you try
I tried your suggestion with VLA object and a regular one.
in both cases I get NIL...
see the lisp I'm using:
(defun c:EF11 ()
(vl-load-com)
(setq obj (vlax-ename->vla-object (Car (entsel))))
;;(print (vla-get-effectivename obj))
(setq instHandle (BmLispGet "Instance" obj))
(print instHandle)
(print instName)
(setq obj1 (car (entsel "\nSelect Block ")))
(setq instHandle (BmLispGet "Instance" obj1))
(print instHandle)
(print instName)
(princ)
Thanks,
Ari.
Howdy, Stranger!
