parametric block with associative hatch
in 2D Drafting
When i create a parametric block the hatch is'nt stretching with the outline
@fkl, Can you show us the drawing as it seems to work in my V22?0
David,
today i tried it again with a new blockdefinition and it works ok.
Dont't know what I am doing different.
Hatch is associative maybe ? that means change shape and hatch will remap to suit.0
In my experience, associativity is often broken. Note first, that I am on v14. And I haven't spent more than a few minutes trying to figure out why. I do know that you have to select the option for the hatch to be made associative. Even if you do, the associativity often breaks.
When you use a "pick point in boundary" method, that is the most unreliable version. So, I am guessing that when moving both the boundary objects and the hatch, the point you selected doesn't move and may end up outside the boundary.
-Joe0 -
FLATTEN destroys hatch associativity, in fact the entire hatch pattern so you end up with lots of independent entities.0
