Custom TIN-style
Look at the Bricscad add on Civil Site Design. Does much more than say pad and batters.0
@ALANH : Thanks for taking the time. I frequently run into the trouble of customizing according to national standard. So I am looking for a BRX/NET-solution of adding a custom TIN-analysis. I cannot find any code example in the BRX samples and in the documentation, so I thought I might ask for one in the forum.0
I have no idea if any of this will help you.
There’s related headers in.
/inc/BrxSpecific/civil/AcDbCivilTinSurface.h
BRXSDK23\samples\brxCivilSample
If you plan on adding stuff to the properties palette
/inc/BrxSpecifi/AcOpmExtensions.h
C++ OPM API.txt
I don’t know how one would go about adding worlddraw, vpdraw, I don’t know if you can overrule AcDbCivilTinSurface
There is also lisp versions just google "Batter lines lsp autocad"0
