Custom TIN-style
Dear all,
has there been any non-LISP approach for creating a customized TIN-style usable through the GUI
To create batters for example?
No hints for LISP required, since we are equipped.
Kind regards
Sebastian
  • Look at the Bricscad add on Civil Site Design. Does much more than say pad and batters.
  • @ALANH : Thanks for taking the time. I frequently run into the trouble of customizing according to national standard. So I am looking for a BRX/NET-solution of adding a custom TIN-analysis. I cannot find any code example in the BRX samples and in the documentation, so I thought I might ask for one in the forum.
  • I have no idea if any of this will help you.
    There’s related headers in.
    /inc/BrxSpecific/civil/AcDbCivilTinSurface.h
    BRXSDK23\samples\brxCivilSample
    If you plan on adding stuff to the properties palette
    /inc/BrxSpecifi/AcOpmExtensions.h
    C++ OPM API.txt
    I don’t know how one would go about adding worlddraw, vpdraw, I don’t know if you can overrule AcDbCivilTinSurface
  • I made a program of drawing the slope lines by using C#.
    Would this be helpful?
  • There is also lisp versions just google "Batter lines lsp autocad"
