Does anyone know use the 3D scanner to measurement mechanical parts?
We need a quick way to test if the accuracy of the products meets the standard. Which software is necessary?
You can get all the surface measurements required to examine the object's construction by scanning it using a 3D scanner. To duplicate or enhance the design, it is much simpler to comprehend the design intent. Scan to CAD is the process of producing CAD from 3D scan data.0
Scanning using a mechanical touch probe is the best way to verify accuracy. Modern scanning using laser or photogrametry is not as accurate. Try searching measurement equipment manufacturers and get one with a spherical ruby tip. It should also come with its own software which usually makes a .STL file to read back into your CAD.0
