Tutorial sendto:shell?
Looking for a tutorial/tips how to connect a LISP for Brics to windows shell sendto. I want to run a couple of very simple commands like PURGE, REGEN and OVERKILL on all dwg's in a folder by right clicking the folder in windows explorer and use SendTo in windows shell to (hopefully) have Brics opening "silently" and perform these tasks on all dwg's in the folder and the close. We're using Simplebim for IFC's in this manner and it's really convenient. The attach shows the windows shortcut to the Simplebim script.
/Mats
Have a look at this.
https://forum.bricsys.com/discussion/34802/accoreconsole-in-bricscad0 -
Ah the command switch is what I'm after... not sure how to tie it together with a script file and being able to right click a folder with lots of dwg's and run the script file on every dwg in that folder.ALANH said:Have a look at this.
