Alternative to ACA Tag and Custom Properties
Civil 3D, AutoCAD architecture and AutoCAD MEP has Tag objects, this is like Attribute Blocks but externally movable, also this can connect to a custom property set data.
This custom set data can extract info about the related object and use it in formulas and others
Is there anything similar at BricsCAD? I wish to migrate but I can not find many info
Sign In or Register to comment.
Howdy, Stranger!
