Alternative to ACA Tag and Custom Properties
Civil 3D, AutoCAD architecture and AutoCAD MEP has Tag objects, this is like Attribute Blocks but externally movable, also this can connect to a custom property set data.
This custom set data can extract info about the related object and use it in formulas and others
Is there anything similar at BricsCAD? I wish to migrate but I can not find many info
Hello,
You can check this link for details about Tags in BricsCAD - BIM: https://help.bricsys.com/document/GD_bimtags/V22/EN_US?id=165079160427
Have a nice day! -
this wokr perfect for BIM objects, but what about AutoCAD 2D objects? Lines, Splines, etc, I need to convert it to BIM ARq or Structural Objects, I am working with MEP and there is not options for MEP.
BricsCAD could remove this restriction if they want.
Howdy, Stranger!
