flatshot of model with section plane
in 3D Modeling
Is it possible to take a flatshot of a drawing with a section plane. I need to create some 2D plans for my colleagues to work on. The only result with the flatshot is the complete model. I know you can get the hidden lines, but then I create a mess with millions of lines.
Or maybe there is a better way than a flatshot.
Hi PiCo
have a look at this forum thread ...i have described a possible solution ...
https://forum.bricsys.com/discussion/38178/perspective-sections#latest0 -
Thanks for the link. I think I can use this one. I also convinced my boss to switch to the Ultimate Bricscad. I hope with BIM I can work more with sections.0
Hi , unless you want perspective I would t making your views as "projected drawing views" in paperspace. Make sections in them .Then use EXPORTLAYOUT. See attached reused from above thread.0
