How to add double click processing protocol in the "On_kInitAppMsg" function(AcDbDoubleClickEdit)
I now need to implement a function of double clicking a specific block response. I inherited the class "CFrameDoubleClick" from "AcDbDoubleClickEdit" to implement double clicking response. But I'm "On_kInitAppMsg (void * PKT)" add double-click an error when processing agreement, I add the function of the agreement as follows "AcDbDoubleClickEdit: : rxInit ();
CFrameDoubleClick* pContactEdit = new CFrameDoubleClick;
AcDbBlockReference::desc()->addX(AcDbDoubleClickEdit::desc(), pContactEdit);” Display error :LNK2019????????? "__declspec(dllimport) public: static void __cdecl AcDbDoubleClickEdit::rxInit(void)" (_imp? rxInit@AcDbDoubleClickEdit@@SAXXZ),?? "public: virtual enum AcRx::AppRetCode __cdecl CMSDApp::On_kInitAppMsg(void *)" (? On_kInitAppMsg@CMSDApp@@UEAA? AW4AppRetCode@AcRx@@PEAX@Z),
How do I add a protocol for double click processing to the "On_kInitAppMsg" function(version bricacad 2024)
you have to create your class
class AcDbDoubleClickBlockReference : public AcDbDoubleClickEdit { public: AcDbDoubleClickBlockReference() = default; virtual ~AcDbDoubleClickBlockReference() override = default; virtual void finishEdit(void) override { acutPrintf(_T("\nfinishEdit: ")); } virtual void startEdit(AcDbEntity* pEnt, AcGePoint3d pt) override { acutPrintf(_T("\nstartEdit: ")); } };then
class AcRxPyApp : public AcRxArxApp { std::unique_ptr<AcDbDoubleClickBlockReference> pRefClick; public: AcRxPyApp() : AcRxArxApp() { } virtual AcRx::AppRetCode On_kInitAppMsg(void* pkt) override { AcRx::AppRetCode retCode = AcRxArxApp::On_kInitAppMsg(pkt); pRefClick.reset(new AcDbDoubleClickBlockReference()); AcDbBlockReference::desc()->addX(AcDbDoubleClickEdit::desc(), pRefClick.get()); return (retCode); }note, you will have to remove all the double click actions from the CUI as they are called first
***remove all the double click actions from the CUI as they are called first
should read all the double click actions that are relevant to block refs
I tried it the way you did, but there was no response when I double-clicked a block, and it always felt like I was missing a process to initialize AcDbDoubleClickEdit
yeah, it’s not really a useful tool anymore because the CUI fires first, blocking your action. Maybe you can replace the ddedit command or use events
Thank you very much. I've decided to take another option
