How to add double click processing protocol in the "On_kInitAppMsg" function(AcDbDoubleClickEdit)
I now need to implement a function of double clicking a specific block response. I inherited the class "CFrameDoubleClick" from "AcDbDoubleClickEdit" to implement double clicking response. But I'm "On_kInitAppMsg (void * PKT)" add double-click an error when processing agreement, I add the function of the agreement as follows "AcDbDoubleClickEdit: : rxInit ();
CFrameDoubleClick* pContactEdit = new CFrameDoubleClick;
AcDbBlockReference::desc()->addX(AcDbDoubleClickEdit::desc(), pContactEdit);” Display error :LNK2019????????? "__declspec(dllimport) public: static void __cdecl AcDbDoubleClickEdit::rxInit(void)" (_imp? rxInit@AcDbDoubleClickEdit@@SAXXZ),?? "public: virtual enum AcRx::AppRetCode __cdecl CMSDApp::On_kInitAppMsg(void *)" (? On_kInitAppMsg@CMSDApp@@UEAA? AW4AppRetCode@AcRx@@PEAX@Z),
How do I add a protocol for double click processing to the "On_kInitAppMsg" function(version bricacad 2024)
  • Its_Alive
    edited June 2024
    you have to create your class
    class AcDbDoubleClickBlockReference : public AcDbDoubleClickEdit
    public:
        AcDbDoubleClickBlockReference() = default;
        virtual ~AcDbDoubleClickBlockReference() override = default;
        virtual void finishEdit(void) override
            acutPrintf(_T("\nfinishEdit: "));
        virtual void startEdit(AcDbEntity* pEnt, AcGePoint3d pt) override
            acutPrintf(_T("\nstartEdit: "));
    then
    class AcRxPyApp : public AcRxArxApp
        std::unique_ptr<AcDbDoubleClickBlockReference> pRefClick;
    public:
        AcRxPyApp() : AcRxArxApp()
        virtual AcRx::AppRetCode On_kInitAppMsg(void* pkt) override
            AcRx::AppRetCode retCode = AcRxArxApp::On_kInitAppMsg(pkt);
            pRefClick.reset(new AcDbDoubleClickBlockReference());
            AcDbBlockReference::desc()->addX(AcDbDoubleClickEdit::desc(), pRefClick.get());
            return (retCode);
    note, you will have to remove all the double click actions from the CUI as they are called first
  • ***remove all the double click actions from the CUI as they are called first
    should read all the double click actions that are relevant to block refs
  • I tried it the way you did, but there was no response when I double-clicked a block, and it always felt like I was missing a process to initialize AcDbDoubleClickEdit
  • yeah, it’s not really a useful tool anymore because the CUI fires first, blocking your action. Maybe you can replace the ddedit command or use events
  • Thank you very much. I've decided to take another option
