Limit on toolbar icons
I was adding custom toolbar icons and received a pop-up that Bricscad could not add an icon to the image list. Is there a maximum number of icons that can be added? I have around 300 custom icons for my current toolbars. If there is a limit is there a way to increase the limit or work around it?
  • Wiebe van der Worp
    edited July 2024
    I've not experienced that ever and one of the menu's I maintain contains more than 1000 different toolbar icons, i.e. (smal+large)*500 in one .resz file.
    Here, the resz file is a renamed and non-compressed zip file and icons are 16*16 plus 32*32 pixel png files.
  • Would you be better off having a smaller tool bar but it pops a dcl with the images/icons.
    As a toolbar is part of a MNU you may be able to take advantage of calling an Image section in the mnu. The advantage is that CAD handles the display and includes Next for more pages.
    I have not tried it as normally use POP menu's. Can provide Image mnu code.
  • Thanks for the suggestions. I'll try the RESZ approach. The pop menu isn't a good option for my office. Twice the clicks, and the toolbar buttons that do block insertions are electrical symbols which can be inserted hundreds of times per day.
  • You must be using sub toolbars flyouts, this is pop menu showing common groups, should be able to do same but as a tool bar. This uses the image section of the mnu, you need a toolbar mnu, one of the reasons I stay away from using the CUI editor.
  • @alanh:
    I do have a few pop-up toolbars (which generally auto-close after a selection) in addition to the always on toolbars, but no fly-outs. That's mostly because I use AutoHotKey to mimic Owen's QuikPik.
    edited August 2024
    Avoiding cui-editor… Indeed!
    So: make an .mnu file, example MyMenu.mnu and MyMenu.resz > cuiload > .cui is generated > if needed, feed that .cui to acad for .cuix.
    Screendump: A spreadsheet (LO Calc) with column I pastable for a .mnu file. Work like a charm for decades now. =IFS() works like a (cond …) statement.
  • Like the idea of using Excel as the interface for making mnu files. Can take a csv file and convert to mnu using lisp. Or do in Excel using a macro.
    Did something similar reading a text file.
    Pity Ribbon is not supported. Only way seems to be to make a cui based on XML code.
  • Thing is, I need some buttons with "greyed out mode", in XML:
    <State>$DieselExpression</State>
    So it is tempting to follow the XML approach, split the sheet in two parts, one for button definitions <MacroGroup> and one for toolbar definitions <MenuRoot><ToolbarRoot>.
    The sheet then generates the full XML.
    Assumption is that BricsCAD can handle "not pretty" XML.
  • If you take a Acad cuix its a zip file just copy and rename to zip, then can look inside, it's so linked between multiple xml files. The ribbon is exposed.
    At least can look at a Bricscad cui. Like the idea make a cui. But is it easier to write a mnu and use menuload ?
  • I managed to create a proper CUI for toolbars. I thought it might be good to share the way I did it.
    You can find it here:
    https://vanderworp.org/cui/
    edited August 2024
    For more see:
    https://forum.bricsys.com/discussion/comment/54463
