BricsCAD 24 Fresh install- Rightmouse button is set to CutClip how do I disable it?
BC Version 23 works fine.. right mouse click loads the context menu but in this newly installed V24 it calls the CutClip functions so I keep on deleting objects from the drawing…
I'm guessing it's set to repeat the last command.
How do I fix it?
I tried the SHORTCUTMENU but that doesn't appear fix it.
Found the fix by disable QUAD.
I've got the same problem, its a little dangerous. I'm looking at customizing mouse, right click cntrl-click but Im not sure what t oset it to..
Hello.
When the Quad is active, the context menu can be displayed by right-clicking a little longer.
A short right-click will display the Quad.
A longer one - the context menu.You could experiment with the SHORTCUTMENUDURATION system variable.
I had the same issue, but didn't want to disable the quad. I found a different setting that stops me from deleting objects unintentionally, but lets me use the quad:
1
