BricsCAD 24 Fresh install- Rightmouse button is set to CutClip how do I disable it?
DavidPereira
edited October 2024 in Other
BC Version 23 works fine.. right mouse click loads the context menu but in this newly installed V24 it calls the CutClip functions so I keep on deleting objects from the drawing…
I'm guessing it's set to repeat the last command.
How do I fix it?
I tried the SHORTCUTMENU  but that doesn't appear fix it.
