While you may find some support for the creation of GeoTiff (images), the GeoPdf is essentially a flawed format that many refuse to support because of that. You're talking about a format where coordinates have first been scaled to page (paper size) coordinates, then rounded to 2 decimal places. Other than being presented in a viewer and/or for page printing, I wouldn't ever want to base a project off of content imported from a GeoPdf.
Export from Spatial Manager
Is it possible to export a GeoPDF or GeoTif (lines and polygons, no raster image) from Spatial Manager?
Don't think so, but you can using QGIS
Unfortunately I don't have acccess to QGIS. I'm looking for a way to export a GEOPDF directly from Bricscad.
GeoPDF seems to be a common format used by android/ios apps, such as virtually overlaying a drawing over a live map of a site allowing you to walk around the site and see where you are on the drawing.
We can do that inside CAD engines (requiring a Windows laptop/tablet of course).
Many thanks for your suggestions. We just bought the Spatial Manager in order to georeference DWGs. The exported Geopdfs or Geotiffs will than displayed in our internal Webgis. I'd perfer a solution with Spatial Manager or bricscad functions rather than buying a second addon for Bricscad.
Put in a support request to Bricsys to ask for this feature to be added to PDF & TIFF printing.
I do know it is possible with QGIS, which is a free application.
If you can write python code. GDAL can create Geotiffs and Geopdfs.
https://gdal.org/en/latest/drivers/raster/pdf.html#driver-capabilitiesUnfortunately GDAL won’t load into BircsCAD due to a .DLL conflict. You may be able to export your CAD geometry using shapely, then post process to create the pdf
