Cannot snap to civil points to draw a 3P
Hi, quite new to BricsCAD and trying to make it fully work so I can share my knowledge with other workers. Working under the civil profile, I am struggling to be able to draw 3D polilynes.
First, upon importing civil points they are too big (look at the image)
to be able to work directly with them. I get lost and I cannot find a way to make them look smaller. Also, when using 3P I just cannot draw a line with my mouse because the points are not snapped to. I have tried to enable snapping in different ways to no avail. What am I doing wrong? I have the correct layer enabled and my civil points are there. I can draw 3P using point numbers too… Any help will be appreciated.
Thanks in advance,
Jose
You can edit civil point symbol and lable style via Civil Explorer panel. Here are some useful related Help articles:
Regarding snapping issue - did you try to turn on 'Snap to Node'? As I see, it should work for civil points.
1 -
Thanks a lot! could not find it!
If your points have a description then you could string the points automatically, this what Civ3D does, have a look at Stringer and Civil Site Design both running under Bricscad, they do way more than import points.
I am in touch with someone looking at stringing points using Python or lisp.
