find and edit tin surface
in 3D Modeling
I have 3 tin surface.
How to find and edit one tin surface if before is everything off?
Hello.
To work with TIN Surfaces, you could use the Civil Explorer panel.
This panel can be opened by using the CIVILEXPLOREROPEN command.In the panel, activate the Civil tab.
There, a tree structure with civil entities will be displayed.Among these entities, there is a node with TIN surfaces.
Expanding the node gives access to individual surfaces.
The available operations can be accessed by right-clicking on a TIN surface name.1 -
Thank you very much Virgli. I like bricscad more and more. :-)
