Hello.
To work with TIN Surfaces, you could use the Civil Explorer panel.
This panel can be opened by using the CIVILEXPLOREROPEN command.In the panel, activate the Civil tab.
There, a tree structure with civil entities will be displayed.Among these entities, there is a node with TIN surfaces.
Expanding the node gives access to individual surfaces.
The available operations can be accessed by right-clicking on a TIN surface name.
find and edit tin surface
in 3D Modeling
Hi,
I have 3 tin surface.
How to find and edit one tin surface if before is everything off?
0
Hello.
The available operations can be accessed by right-clicking on a TIN surface name.1 -
Thank you very much Virgli. I like bricscad more and more. :-)
0
