Disable or redefine ctrl-shift-middle click
Some years ago I posted about wanting to disable the ctrl-shift-middle click 'rotate view' function:
At that time there was a suggestion to redefine the ctrl-shift-middle click and it worked. Now I find that even after redefining it, it still rotates the view. I am using version 25.
Does anyone else experience this same thing? Are others able to redefine this successfully?
Since that time new variable CTRLMOUSE appeared, it controls predefined mouse shortcuts. You need to turn it Off to disable view rotation by key + middle button.
Thank you!
