Custom Blocks Using Expressions and SSM
Is it possible to use expressions within a field? The way my company sets up drawings, the elevations will almost always be on the sheet directly after a partial floor plan. I would like to put a field that uses SSM to add 1 to the current sheet number so that it references the next sheet without having to insert it manually. Is this possible? I am very new to CAD so please explain it simply.
